might be a wiring issue.... possibly a bad solder joint, might want to tear into the harness and take a peak.S13 240SX wrote:no... and i dont understand this... my last CAS took a crap...
i got another and now this one is taking a crap now... its clicking very loud and getting very hott and i shut th car off and now it dont start!!! i'm sick of it.. because i dont get it why??
why would it be clicking and getting hott???
so your saying the 3 bolts 10mm.. take them out and add some more washer to them? k i'll try it.digzsublime wrote:If you are not running the upper timing cover, you definitely need to put some small washers between the CAS and CAS bracket.
Do this when you install another CAS. Hopefully it will keep you from eating another one. This will likely solve your clicking issue. Well, I hope so.
