power comes from the relay box by the battery. there is a green fusible link that sends power to ignition switch. the 10 amp fuse for ignition switch is for incoming power so ignore. carefully inspect fusible link to see if blownSlidinSideWayzSR wrote:where's the wire go after it goes through the ign switch fuse does it run in to anything like a relay that im missing or somethin
