he answered yes, then it ended up being a factor in this problem? hmm weird........MoogLe wrote:is your throttle body closing entirely?
So you are still on the stock throttle body with just the q45 tps? if thats the case i would check the IACV. If its with a q45 throttle body adjust the screw on the front of the TB for the coolant temp activated idle control.homesivan11 wrote:car still wont car, or even a temp to start, getting spark, do you guys still think is because of the tps wiring?
