ka24boos13t »
https://forums.nicoclub.com/ka24boos13t-u38446.html
Tue Nov 03, 2009 7:41 pm
I've heard that it's longevity is quite high, especially when compared to HDD. Many are quoting 10+ years now and much more depending on the situation. In a server environment where a majority of the activity is reading data, the longevity is considerably higher since there is only limitations on write cycles (not that this is a huge issue, more on that in a second). Hardware failure is really a non issue and given that current SSD have error correction, I don't see why one should really expect less than what it is "rated" for. The whole system is really superior by simplicity, no need to spin up/down the platters, no moving heads etc. A lot of the earlier complaints were about the amount of write cycles allowed but what most people didn't realize is that it's rated for that many write cycles to EACH CELL. An efficient controller would spread out the writes across as many cells as possible, virtually eliminating this problem for the majority of peoples use for an SSD.
I'm concerned about the ability to obtain data once one does crash though. So far it's been extremely hard if not right near impossible to recover data off a fried SSD. Most consumers are to ignorant and worry free to back up there data. Although 90% of the time it's not a terribly big deal since they don't have anything extremely important stored on their HDD but when they do, and it crashes, it's usually possible to get the important data back no matter if it was a bad sector/cluster/partition or a hardware failure. Hopefully it will teach some people a lesson.
