Can some one clarify this for me....R32 vlsd in a s14
obos
I bought a r32 vlsd and I want to install it into my 95 s14 with stock KA motor. The lsd has abs. So from what information I have gathered, the vlsd should physically fit, right? Also since my car is non abs, I will need an abs driveshaft to work too, correct? Can I use the skyline axles with my stock spindles or do I have interchange anything before the stock axles will fit? Any info would be greatly appreciated.
Thanks
Wulfgang
You should give your R32 VLSD to me and let me take care of the issues. And then I will give you my J30 VLSD which is a direct fit into your S14, no mods needed.
But to answer part of your question, the ABS is not an issue. The ABS sensor adds a little length to the VLSD, but your driveshaft play should be more than enough to handle it.
As for the output shafts, I do not know. If they have 3 pairs of bolts each, then they will probably fit. If they have a 5 bolt star pattern, then they will not fit.
Carl H
swap the guts into the s14 rear end if you want a lsd now, else with some coercing the r32 one will fit, gotta swap rear covers tho.
obos
Thanks for the input. I guess I'll have to look at what I got a little closer and decide on how I am going to do this. Thanks again.
obos
Took a closer look at everything and I guess I will have to swap the rear covers. No problem there. It seems that my axles though are my biggest concern here. Can I just swap the output shafts with my stock ones, or can I just swap the axles with the r32 axles?
