How much do you want for the cross rails? I might buy them.billsims wrote:I have already removed the cross rails. I won't ever use the rails and I am not crazy about the silver color with my red body color. I would like to remove them altogether, but it appears it may leave a gap or unfinished look in the roof channel if they are removed. I know the base models don't even have them and, frankly, that is the look I want.
I was going to go this route, but I'm concerned about plugging the holes right. Since I was considering painting the roof black anyway, maybe I'll just paint have the roof rails painted at the same time...philipa_240sx wrote:It is possible to remove the roof rails on each side. Just to give you an idea what's involved:
1- Remove the trim pieces from each end of the roof rail2- Remove the 4 bolts holding each roof rail in place. If they do not loosen, you will have to partially remove the headliner inside the vehicle to access the nuts underneath.3- Remove the rail. You will now be left with 4 holes in the black plastic trim piece (drip molding) running the length of the roof.4- Plug the 8 bolt holes that held the roof rails in place. This way you do not get water inside your vehicle.5- Purchase 2 new roof drip moldings from an S model Rogue. These will not have any holes in them for the roof rails. Cost is about $150USD for the pair. Remove the old ones and install the new pieces.
As for painting the factory rails, this is possible but I would suggest having the rails removed and painted separately. Painting them on the vehicle will be difficult as it's hard to avoid over spray and you cannot easily paint the underside.
I advise you to remove than re-attach your hood deflector which is really quite easy, maybe you could replace the tape protecting the paint if need be.Qashqai wrote:I have a pair and I don't have any complaints. However, I do have a hood deflector and it whistles a lot! But that is a trade of: having a dent on the hood or whistling? of course whistling!
