Can not enter programming mode and no beep when key left in ignition
Post all your Nissan electronics, car audio and stereo questions here!
Beany
Car: 2002 Pulsar n16
Well here goes, I have seen a couple of posts with the exact same problem as me but with no positive outcome, I have a NATS key where the remote is part of the key (2buttons) this comes apart, one side is the blade with the transponder in the other the remote part with the board in, figured if I keep the original blade and transponder and swap the broken board part it would would work,
The problem is my car won't enter programming (tried the in/out thing loads of times) no lights flash, also no buzzer when key left in ignition, all does open with key in door lock, all does lock with switch inside, interior light comes on/goes off
Checked fuses etc
Anybody any ideas??
Thanks
