Can my exhaust handle it?
frsh13
Car: 1991 240sx coupe
Currently running a 3inch downpipe halfway back, then it bolts up to my 2.5inch 5zigen exhaust. Running around 10 psi. Am I playing with fire here and should upgrade ASAP or am I good for another few months so I can save up some money?
Nissan_240sx
Car: 1992 240sx
you should be ok, although you'd gain some with a complete 3"
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
Dude just stick with 2.5 man...u get WAY more torque.
MarkEmark
Car: fully-built '95 240sx KA-T
frsh13 wrote:Currently running a 3inch downpipe halfway back, then it bolts up to my 2.5inch 5zigen exhaust. Running around 10 psi. Am I playing with fire here and should upgrade ASAP or am I good for another few months so I can save up some money?
I'm still running a 2.5' exhaust, and I'm running 16 psi from a GT32. However, I also have an electronic exhaust cut-out at the end of the downpipe, and with it open it's substantially faster than when the exhaust needs to go all the way out the muffler (I'm running no cats or resonators).
I think you'll be fine; you can always upgrade.
2FourTee
Car: 96 240sx - Supercharged ka24de
You'll be absolutely fine. I've heard idiots on here and other boards before that act like 2.5 inch is too restrictive for turbo, but it's not. A lot of factory turbocharged cars run exhausts 2.5 inches or less.
Sure you'll gain some spool up and top end with a larger exhaust, but it won't hurt anything.
crzycav86
Car: 93 Nissan 240SX KAT
no, you're not playing with fire, and yes, your exhaust can handle it.
your exhaust is not going to spontaneously combust or catch fire if it is too small.
