Can my current ka24e alternator handle this amp?
Post all your Nissan electronics, car audio and stereo questions here!
IKGamex
Car: s13
I'm thinking of installing a 1200watt amp in my car, but I'm not sure if the current alternator will be able to handle it. It's a newly rebuilt alternator, but unfortunately is still the stock KA24e one. Here's some specs on the amp:
http://www.edesignaudio.com/pr...id=44
I currently got a 250 watt amp in the car, but it doesnt even make the lights dim unless I have it cranked up all the way. Soo....will this work?
zerepdivad
Car: '90 240sx . '02 Lexus IS300
What size power wire are you running? Do you plan on wiring up at 1 ohm?
IKGamex
Car: s13
Hmm not sure about the size of the wire, I'd have to ask the previous owner. But I'd have no problem re-wiring if I'd need to. And yes, I do plan on running this at 1 ohm.
IKGamex
Car: s13
Bump. Hoping to buy the amp this weekend.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Your going to need AT LEAST 4 gauge wire to run that amp. The alternator really isn't designed to handle that load, so it's more of a when is it going to fail rather than if. Personally, I'd just run it till it fails, and then go someplace that has a lifetime warranty and get good at swapping them out.
