sicwitit »
https://forums.nicoclub.com/sicwitit-u90139.html
Sun Oct 30, 2011 6:31 am
unless you buy shocks, struts that are designed for a lowered ride height, none of the shocks that are designed to replace the factory struts, shocks will operate within their designed parameters. the only way a stock type of strut can handle a lowered ride height would be to cut the vertical control arm welds on the strut body, and reweld them 1-2 inchs higher on the strut body, this would move the entire strut down and keep it in its optimal operating zone. finding some rear shocks should be easy. do a little thinking outside the box.
or do it the easy way and buy some coilovers
