Can KA24DE take 100hp increase?
ILikeMy240sx
Car: SR Power
Just wondering... on stock internals, can a KA24DE take 100hp increase with a turbo on the crank?
Im trying to figure out how much a stock KA can take daily driven so I can figure out how Im going to be putting things together...
BadMojo
Car: 2007 Mazdaspeed 3
Yes. With proper fuel management, plenty of people are doing that on stock internals. Assume the 240SX puts down about 130 to the wheels (that's probably a bit charitable)...230hp to the ground can be done on stock internals.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
Yes if the motor has been taken care of. Just install it there is no way to tell. If it pops replace it, ka's are cheap.
SeVa-S13
Car: '05 GTO 6spd
There's a very good and easy way to tell. Do a compression test.
574-240sx
Car: Nissans, Toyotas, Subaru
Yes first do a compression test. My car is daily driven for the most part. A little more than a month and my car is doing fine. 141K and still ticking. Also a wideband helps to keep an eye on air/fuels. Nick
drifts14x
Car: Cars, Motorcycles, Drifting
Seriously, it shouldn't be a big deal, and btw, I have 190k on my car and she still runs perfect.
ILikeMy240sx
Car: SR Power
Ok.. so how many HP are people putting @ the wheels on stock internals assuming its tuned with SFAC and a wideband..
sorry for these newbie questions but i need to start somewhere lol
Drift Machine
Car: 1991 KA-T 240sx
stock internals and 6psi i'm putting out 220hp at the wheels.
But you might want to look at the sticky at the top of the KA-T page to get an idea of what people are putting down.
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
ILikeMy240sx wrote:...assuming its tuned with SFAC and a wideband.
Fuel tuning is only half the equation...you're forgetting about timing.
Stock timing will blow things up at ~6psi and up...unless you retard the base timing a little. You can get away with 9psi if you knock the base back to ~16 BTDC, but any more than that, you're asking for trouble.
So I'd say to keep it safe, run 8psi or less, and ad more fuel than needed.
Now, if you address the timing issue (like use a retuned ECU, JWT makes a few different programs), you can do much more.
300rwhp is not uncommon for stock KAs with a T3/T4, and 12-13psi or so, and a JWT 50lb injector/Cobra MAF setup.
Many have dyno'd ~350rwhp at 16-17psi, stock block.
- Brian
turtl631
Car: S14
- Brian
And it is quotes like this that are my inspiration
574-240sx
can JWT use a 300maf instead of the cobra maf.
SeVa-S13
Car: '05 GTO 6spd
JWT can do anything you ask them to. And the Z32 MAFS is probabaly the most common upgraded one so of course, yes.
IvanAtSPRacing
Car: I make cars fast
Bone stock 115,500 mile KA DE with PK turbo kit, fuel system, IC, and AEM EMS made 404 RWHP and 409 TQ has run 12.78 @ 117 mph
http://www.phatka-t.com
Kinesthesia
IvanAtSPRacing wrote:Bone stock 115,500 mile KA DE with PK turbo kit, fuel system, IC, and AEM EMS made 404 RWHP and 409 TQ has run 12.78 @ 117 mph
It's quotes like these that.... just give me WOOD
hannibal
Car: Red Line to Glenmont
But the Nissan ECU (JWT tuned included) still cant retard timing according to boost pressure. Its based on rpm and engine load, correct??
klattr1
Car: GT42R powered S14/KA
yes. the jwt ecu has no clue how much boost you are running.
ILikeMy240sx
Car: SR Power
How about a simple device like MSD 6BTM... It's probably not as good as a say reprogrammed ECU but... it's a safe/efficient way to prevent detonation for lower price...
C-Kwik
IWannaS15 wrote:But the Nissan ECU (JWT tuned included) still cant retard timing according to boost pressure. Its based on rpm and engine load, correct??
It doesn't need to. The ECU will see a large amount of air flowing into the motor for the given load(TPS) and RPM. The stock ECU will even back off timing as the MAF signal increases for a given TPS and RPM. JWT's maps will be more inline for what is needed when running a turbo however.
