Can it really be that bad need help s15
Kaforlife
Car: 1992 240sx
Alright can it really be that bad the six speed transmission from the s15 sr20det I'm really looking into geting one but people say not to because he transmission is garbage. What makes it garbage no one can give me a reason they just say it sucks, hope some one here can give me a couple of reasons thanks
Hijacker
Car: '92 240sx Convertible
'94 F-150
I wouldn't say it sucks.
The main problem arises from kids trying to do high rpm clutch dumps on the gearbox for burn outs and drag racing.
The 6 speed has one extra gear that fits inside the same sized gearbox, so the other gears had to be cut slightly thinner to make the squeeze possible. Because of that, the gears themselves don't hold up to abuse like a 6000 rpm clutch dump.
Now to go out there and say the gearbox is garbage is an unfair attack on the gearbox. The 6 speed is nice and if you're wanting a fun daily driver and light road racer, the 6 speed will get the job done very well.
Kaforlife
Car: 1992 240sx
Oh i didnt know know that so as long as i dont do high rpm clutch dumps it should be ok I'm not really into drag to much moree into like autoX so it should be able to hold up there
virus77
Car: 95 S14, 71 240z, 97 e320
don't forget you need a diff to offset the short gearing of the 6 speed and to have a speedometer
Hijacker
'94 F-150
For auto-x you should be fine.
But yeah, you will need the S15 rear diff to accompany the trans. Added bonus as it's a helical LSD
Kaforlife
Car: 1992 240sx
a speedometer i cant just wire it up to the one thats already in the car?
Hijacker
'94 F-150
Do some research and you'll find that the S15 trans has a divorced speed sensor. It's located on the diff and has a different gear ratio for it's signal output. Because of that you need a converter box to change the signal pulse to one that the stock cluster can read.
Kaforlife
Car: 1992 240sx
Oh thanks for all the info I didnt know that it was so much different then the s13 and 14 I thought it was just one more gear but I see theres a lot more to it.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
If you want to dump $4k on a new transmission , the NISMO 6-speed for the SR has the speed sensor on the transmission
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
I beleave the s15 flywheel is about 26lbs and the s13/14 flywheel is about 20lbs. That should add some more stress
