can injectors fail suddenly?
anti_flag_army
Car: 91 Miata, 90 240sx coupe
So weird thing, I drove my car home, and it was running perfect. Me and my friend hang out for a few hours and then i go to drive him home and i can immediately tell im missing a cylinder.
I checked spark first, and it was fine. So reason would have it that the injector isnt working. I will check in the morning, because its like 1 am right now, but my question is, can injectors just fail for no reason like that?
91nissantwo40sx
anti_flag_army wrote:So weird thing, I drove my car home, and it was running perfect. Me and my friend hang out for a few hours and then i go to drive him home and i can immediately tell im missing a cylinder.
I am having the same problem with my car. It has something to do with ethier the spark or injectors. Sorry to steal your thread but maybe someone else out there can help both of us out. Btw i would like to find out if my spark is in good condition, any help on how i can find this out? thanks
yellow2000SR
Car: 92 Nissan 240sx 98 Ford Escort ZX2
If something sneaks by the filter it could clog the injector.
Are you sure its not timing? I jumped timing on my ZX2 and I thought I was missing my 3rd cylinder b/c of the codes comming up...
Dattebayo
"Jump" timing? haha Not likely with our timing chains... Unless your motor is REALLY bad.
I would think its time for wires and/or plugs, cap and rotor, but first, did you test all wires for spark with the plug in the stem or did you just use the screwdriver method?
dickie
Car: Killer Turtle
injectors fail all the time. troubleshoot to make sure that is your issue, or just replace it with a friends' plug to see if that helps.
replacing one at a time is a temp fix though, save up for 4 and replace your filter, purge your lines with good gas before you put it back together.
VirginiaPS13
Car: 89 S13 Coupe
2005 Acura TL
Injector problems suck..I think the are even worse on SoHC engines. I had a problem with mine missing, started all of a sudden like that. I changed plugs, wires, blah blah blah..full tune up fuel filter etc. still was missing. Then I got a set of used injectors, still missing, got another set of injectors started up still missing. Well for some reason I grabbed one of the injectors while the car was trying to idle, and noticed the idle changed..WTF!! Well I turned it like a dizzy and the car ran better the more I rotated it. Upon further inspection I noticed one of my wires on that injector was busted..fixed the wire. problem solved..Maybe not ur problem, but maybe it could help someone?
romerider153
Car: twin turbo vh41 tube chassis s13, s14 and s13 ka-t daily, someone buy my s14
i 2 am having the same problem but my car wont start and i narrowed it down to injectors i used a noid light to figure out i have no injector pulse at all still no answer to y but maybe you should check your injector harness with a noid light that way you atleast know if its a electrical problem or mechanical not to thread jack
