KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Mon Jul 10, 2006 10:25 pm
Why does everyone think it'll be so laggy? It has a .60 A/R turbine housing, whereas the most common T3/T04E units have a . 63 housing. It'll spool up just under 4k rpm.
.70 A/R housing is good...lots of flow, however, as mentioned above, that .54 trim compressor wheel runs into the surge limit above around 8-10psi. You might consider sending it out for a compressor wheel change to a .50 trim.
