so i would need to get like a custom manifold? or what? im still a noob about turbos so dont mind some dumb questions.awesomenick wrote:the manifolds aren't interchangable. but you could use an sr turbo on a ka.
so that will be a yes and no answer rite? because my cusin have a stock sr20det turbo kit + intercooler kit, i wanted to buy it off of him because he has a new turbo kit etc. and its just sitting in his house takeing up space, and i want to stick with the KA24DE. i dont want to go with and sr20. yea so what things might i need if he gives me every part of the turbo that came off from his motor? (remember im still a noob about turbos sry.......)WDRacing wrote:I try not to make disparaging comments to the noobs...they don't know me yet
But I guess high would probably be a fairly accurate estimation
WDRacing wrote:Well, I was referring to the other guy, not you when I said the noob stuff.
You'll need fuel injectors, a way to control them, a new manifold and hopefully everything will line up on the exhaust side. Which it should assuming he gives all of the right parts.
how much u think everything would be?
WD
hahahaha im use to chatting like crazy so i kinda write my words differently and im only 17! not 21 lolChezedik wrote:Also, vaj (he he), try a little better grammar, it will make your posts easier to read.
PacMan86 wrote:my recomendation is to go to japan power or jdm and get the whole sr20det swap. It would be easier and you car will perform better.
Chezedik wrote:Easier than installing that on the current motor!?!?! Are you high? Have you ever done a motor swap?
WDRacing wrote:Whoever says doing an SR swap is easier then installing a turbo kit...well I'll just say that it simply isn't true.
Chezedik wrote:Would you not say that they are high?
Sh*t, I am STONED; and I still even know that installing a turbo kit is a lot easier than doing a complete motorswap, he must just be straight retarded.WDRacing wrote:I try not to make disparaging comments to the noobs...they don't know me yet
