can i use s14 rear brake rotors with my s13 caliper?
MoogieBoogie
I'm upgrading to 300ZX brakes. After reading "The Definitive 300ZX Brake Swap" (http://importnut.net/300zxbrakeswap.htm), it seems that swapping the rear Z32 brakes is too much of a hassle for a novice.
So after searching, I found through this link (zerothread?id=145456) the rear brakes for the S13/14/15 are the same.
On my 91 SE hatch, I plan on doing the 5 lug conversion offered by Intensepower.com, with the 300ZX front brake conversion. Could I leave the rear brake calipers in place and get the S14 SE (5 lug) rotors and pads? Would that work?
Thanks,-Brian.
Toshima
Car: 93 240sx, 93 sc300(m/t)
Yes you can use s14 se rear rotors or you can redrill your s13 rear rotors.
