Can I use my timing chain from my old 240?????
240Knightrider
Hey as some might know I just bought another 240 with 2 big problems, the clutch is slipping bad (stupid old owner doing burnouts all the time). and the timing chain is making a terrible noise, much worse than my old 240s(which eventually went away).
I was just wondering If I can use the chain out of my old 240.
thanks everyone.
Altiman94
Car: 1989 Nissan 240SX
I don't see why u couldnt. If ur clutch is good you could also use that from the other car as well.
574-240sx
Car: Nissans, Toyotas, Subaru
First question what year is your new 240 and mileage?
240Knightrider
my new one is a 92 with 150kold one 92 with 220k
574-240sx
Yes it will work. Sound like you need some new tensioners and guides. First pull your valve cover off because there is a bracket on the top that quiets the timing chain so it doesn't it the valve cover. I had that bracket break off before and the noise got really loud. I had bad tensioners and guides though which made alot of extra slack which broke the bracket. I would seek advise from a expert mechanic who has experience working on 240sx's first hand. Let them listen to your car. Nick
