can i use my stock fuel pump
josephg15
Car: 1992 240sx
i just did the sr20det swap in my 92 hatch and i ordered a walbro 255 fuel pump but the company where i ordered it from is laging. my question was is it ok to run my stock fuel pump for now till i get the new one in? (it should be in next week) should i only cruise or can i get up on the gas a little? will it be ok? and what should i look out for when running the stock fuel pump? thanks any information will be great. thanks please get back at me asap.
slow s13
Car: cars, photo, music
id say it would be fine for stock boost
highmilehatch
If your going to drive it on the stock pump, at least stay out of boost. You can wind the motor out a bit, just don't give it too much load.
vutony
ur fine till it arrives...i ran stock for awhile
kamikazestorm420
its fine for stock boost.
ive been running on stock fuel pump for about little bit over a month now.
i will however be upgrading the fuel pump before i up the boost.
da40
Car: 1995 SE 240sx
yeah im with kamikazestorm420 u can go on 6-7psi anything after that is really pushing it ,i ran it like that but my fuel pump burnt out on me in like a week1/2 so try to get that walbro asap
Vanguy
Car: 1995 Nissan 240sx SE
Highmilehatch sounds like he is speaking from experience. I was running my stock pump for about a month. The car would warm up and stop making any midrange power. From 2100rpm I'd get half into the throttle and the car would go nowhere. I'd pick a lower gear and off I'd go. I had to keep out of the throttle until 3k or more. Having experianced that and given the afordability and ease of install of a Walbro, I wouldn't tell anyone they should run the stock one. But, for my month of use the motor doesn't seem any worse for the wear and I never heard it ping.
karmakaze
Car: 98 240sx SE
josephg15 wrote:i just did the sr20det swap in my 92 hatch and i ordered a walbro 255 fuel pump but the company where i ordered it from is laging. my question was is it ok to run my stock fuel pump for now till i get the new one in? (it should be in next week) should i only cruise or can i get up on the gas a little? will it be ok? and what should i look out for when running the stock fuel pump? thanks any information will be great. thanks please get back at me asap.
its not worth the risk. if you have any other form of transportation, then don't do it.
