Can I use FX35 rims?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
harp00n
Car: G35x '07
I use FX35 18" rims with 245/45/R18. As far as I know (I'm not sure) they are 8" wide. Can I use 225/50/R18 tyres on them? Some tire calculators tell me, that I need to use at least 235-wide tire....
pfarmer
Car: 2008 GXS with technology package
harp00n wrote:I use FX35 18" rims with 245/45/R18. As far as I know (I'm not sure) they are 8" wide. Can I use 225/50/R18 tyres on them? Some tire calculators tell me, that I need to use at least 235-wide tire....
Are you saying you are using FX35 Rims or can you use FX35 Rims?
I show the FX35 Rims as having both the wrong offset and the wrong bore compared to the 'G'. They do appear to be the same as the 'M'.
Perry
harp00n
Car: G35x '07
Perry
Well, I had wrong title I use them (but with other bolts than stock) and they seem to be ok. But I want to swap to 225/50/18 and I'm not sure if it's possible (245 looks pretty narrow on them now...)
pfarmer
Are you saying you are using longer bolts because the bore is too small. If so then you just transferred the stress that is suppose to be carried by the bore to the bolts in the form of sheer stress. I list the bore for a FX35 as 66.1 and that for the 'G's AT 67.1 .
Not sure of the wheel size but if it is 18x8.5 then the tire size is listed at 265/60 - 18
Perry
toddnos
Car: 2003 infiniti g35 sedan
can u post up some pix of your car with the FX rims on it?
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
