can i use a pathfinder axle on a 95 2wd
rbZphil
Car: 1995 nissan pickup 2wd, 1988 corolla fx 16 gts, 2001 ford Excusion diesel, 72 240 RB z
i have a 2wd 95 nissan hardbody and my h190 took a crap on me i want a stronger axle and want to use the 233 is that possible? will it line up and everything or not? and if not what would i need to do?<center><br /><br /><br /><br /></center>
Modified by rbZphil at 1:00 PM 2/14/2010
rbZphil
I guess i will just find out if it works and then let you all know.... cause im getting a axle from a 91 pathy on sat
JC87HB
Car: 1987 Nissan D21 HB
the spring perches will need to be welded on seeing as pathys are coil sprung in the back... and you will have do go SUA if u want it to be stock.. and if you go SOA you need to get 4x4 truck springs and do some welding!
rbZphil
i looked at a 91 and a 92 pathy and they were both spring under.... dont know yet when they switched to coil?
goomba1
Car: 1990 hardbody, 1993 hardbody
id be interested in that myself i need a beefier rear axle
