Can I use a fuel injector cleaner in my 13 M37x?
JiGG3d
I was wondering if I can us a fuel injector cleaner to get better performance and mpg... If so what kind?
Also currently I'm getting 10mpg what can I do to fix that ? The first day I got the car it said 20mpg till I had the battery changed some please help
How can I get better MPG?
adeedpb
Car: 2012 M56
2005 BMW X5 4.4i
2005 G35 Sedan - SOLD
1995 Ford Taurus SHO (Supercharged) - SOLD
There was a discussion here before about it and I believe the majority liked Red Line products the most, as did I.
http://www.amazon.com/Red-Line-60103-Co ... ds=redline
Larz
Car: 2019 Q70-L RWD
I have used both RedLine and Seafoam in the fuel tank. Both work great and cause no troubles. Redline costs about $15 per bottle and Seafoam costs about $8. Seems Redline could be a better product. There was a discussion on these two but the search function is not available at the moment. I will edit this post when search comes back online.
EDIT: here is the link to the thread:
post6676727.html?hilit=redline#p6676727
szh
Car: 2018 Tesla Model 3.
I use BG-44K, although it is not considered the best anymore by some people.
You may find that a pressurized injector rail cleaning at the dealer may be best - remember to ask for that and not their "add the equivalent of BG-44K" injector clean service.
Z
beachbum718
Car: 2011 Infiniti M37 S
Gumout tune up.found at autozone.i always use it in my cherokee.and used it in my brothers infiniti i35.pour 75% in empty tank .then fill it.25% in engine where you pour your oil in.its proven to work better then sea foam.on youtube there s proven tests with scopes in engine with before and after shots. Ill try it on my M .before my next oil change.which will be in 3 k miles
SwissCheeseHead
Car: 11 M37x, 94 BMW 530i
I would only use Redline SI-1 Fuel injector cleaner. I would not trust anything other than motor oil in the crank, or anything in the brake booster. Details are in the thread listed above (thanks Larz!)
silberma
Car: 2015 70QL
A fuel injector cleaner is a waste of money. First fuel injectors have become very reliable. Second, all fuels contain detergents that keep the injectors clean so they can meet the EPA emission standards. If you buy tier 1 gasoline you will get more detergents than the EPA requires. I buy only brand name gasoline which exceed the EPA requirements. Shell for example has 5 times the mandated amounts.
Years ago a fuel injector cleaner made sense but not now. When was the last time you heard about a fuel injector that had to be cleaned or replaced?
