Everywon in sweden tells me that is how to do the timeing with 2 exhaustcams on ca18det.But i dont belive thats right.r34 gtr wrote:uuum, the marks need to be lined up properly. i dont think moving the gears a tooth to advance/retard timing is a good idea. ive only done it by accident, and the car ran terribly. i didnt notice the little dot on the cam gear, i just assumed it was factory timing. sorry if i caused any confusion.
I want to reiterate that I can't prove this at the moment, I read it a while ago and saw proof however my memory is crap and i can't find the original info so please don't just advance it 10 degrees.. check I'll try to find more info tommorownocwage wrote:If I recall the exhaust cam is retarded 10 degrees compared to the stock one if you line it up the same.By jumping the tooth you'll end up with it closer to 'stock'
I can't prove this however
Have you done it get.How did the engine felt?r34 gtr wrote:you boys have peaked my interest. i might go fiddle with my intake cam timing tomorrow. actually, scratch that, i broke a tail light replacing the gaskets and its supposed to rain. i will however do it friday. one tooth forward for 10 degrees you say?
If it has the nipple for the CAS it is an exhaust cam.r34 gtr wrote:hmm, makes me want to go re-adjust mine.... though i have no idea if im using the intake or exhaust cam from the ca16.
