scarboroughdub wrote:the technical data that i have is from personal experience, all the cars that i have built seemed to suffer more from a atmospheric dump of air if the bov was located on the hot pipe, when located on the coldpipe these issues went away drastically.
hence why all these guys that run a atmo bov and use decel options like on the SAFC to compensate for lost metered air in the system.
i have found that placing the bov on the cold pipe is very benificial then the hotpipe.
either way take it as you want it i know what works since it worked for me.
I think you are posting from a standpoint of keeping the engine from stalling. While I don't see how it would make a difference, My post comes from a standpoint of what a BOV was designed for. To reduce/eliminate surge when you close the throttle during boost. BOV sounds are side effects. Saving your turbo is the primary purpose. From this standpoint, keeping the motor from stalling is irrelevant. One can simply recirculate the BOV to keep from stalling.
On a side note however, if you are not stalling while running an open atmo BOV, I have to wonder if it's releasing enough air. If the BOV does not allow enough airflow to escape to at least keep up with the airflow the turbo sees, it will surge. The amount of airflow should not be vastly different unless you are seeing a large pressure drop across your IC core. And in this case, it would mean the turbo is actually seeing more pressure than the BOV does. This could mean your turbo may be seeing more surge then it should.
