MinisterofDOOM wrote:2nd gear start isn't bad for the trans. Why would Nissan engineer a $50,000 car in a way that would cause it damage? Earlier Qs had shorter 1st and 2nd gear that made the 2nd gear start adequate for average driving but left 1st available when needed. Later Qs with 1st gear start from factory had taller 1st and 2nd gears which suited the new TCU program.
Not entirely true... the '90-'92 had 2nd gear start, but the '90-93 had the same transmission. The 1st gear start keeps the transmission cooler and should improve it's servivce life. I think Nissan switched to the 1st gear start partially in response to transmission failures in the early Qs.
The only advantage to 2nd gear start would be smoother starts and better control in ice and snow.
Heath
