Can I upgrade Fuel Injectors without larger turbos
RedZed
Car: 1991 Nissan 300zx TT
2008 BMW X5 4.8i
Hello,
I am thinking of upgrading fuel injectors. my current mods are intake and exhaust. I am thinking of getting an ECU and am thinking of getting it programmed for larger injectors. I also have a boost controller that I haven't installed yet.
Can I get larger injectors with these basic mods and an ECU upgrade? I don't really want to set up the vehicle to run rich but at the same point it runs really rough at idle and the injectors are stock so I think its time for an upgrade.
Eventually I would like run some very high hp numbers on it but for now its mostly stock and not running right.
thank you.
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
RedZed wrote:
Mon Dec 23, 2019 7:32 pm
Hello,
thank you.
Yes you can, especially if you plan on more power later. I currently run Nismo 740 with a SZ tuned chip on oem turbos.
But you should confirm the idle issues first before any upgrades, if it turns out to be a non injector issue then you would still have rough idle after upgraded injectors and ecu. Could be just connectors causing idle for example.
