Can I Try To Run The Car With Out Valve Cover?
rico05
Car: 1992 RMS13 w/ CA18DET
I'm not a sycho, but I popped my valve cover to try and uncover the cause of my clacking timing chain. The upper guides are already removed (done before I owned the car) and the upper tensioner seems to be working. I rotated the engine via the nut on the p/s pump, but I think I need to try to turn the car over to see if I can pinpoint the noise. The car will not be run (no spark plug wires) just kicked over to look/listen.
BTW: if anyone wants to throw in their $.02 on the reason for the noise: Timing chain is in perfect shape and all guides (well, the ones that I can see) look to be in good shape.
rico05
Nevermind. I grew some balls and tried it. No problems, or clicking. I am just gonna take the car to a shop and see what they say.
95lsdohc
why did u do that??? your engine bay must be messy from oil....you def have balls though...but don't trust them all the time bro
240sxGT
Car: 97 Nissan 240SX SE
98 Nissan Maxima SE
93 Subaru Imprezza
Yeah, there has got to be oil all over the place, tried with just the oil cap off can't imagine it with the whole valve cover off.
rico05
Well, w/o spark plugs, the car won't run...just turn over with the starter. No oil spray at all.
alex7542
Car: Racing and high horsepower
heyi did that in my 240 ran the car without valve cover. but i did turn on the car and no oil would squirt at idle. only if i would have rev it up oil would squirt
alex7542
ohh and also mym otor blew because i guess it had a bad oil pump and i wasnt aware so maybe a car with a good oil pump will throw oil everywhere
dareo
Car: 1993 Q45, 1989 240sx
i tried that once, starting it w/o the valve cover on. in a few short seconds lots of oil was everywhere.
fuzion
Car: Cars.. Web/graphic design.. Yuppp
wait theres supposed to be oil in there? ;)
slow s13
Car: cars, photo, music
my budy did that in a mitsubishi and it sprayed on the wall, damn that was funny
95lsdohc
dude...why are you doing all these stupid things to your car. Don't start your car without spark plugs, u can deg screw **** up. I think you should just give up and find somebody who can maybe help. So far everything you have done is pointless and some of it is harmfull to your car.
rico05
Sure. Whatever. Running w/o spark plugs for 15 seconds in not going to screw anything up.
karay240
so how exactly did you run your car w/o spark plugs? Or are you talking about just cranking the motor?
TurbNurb
Car: Cars
i did it once on an old toyota. i just got a cardboard box and set it aound it. It worked pretty good.
Turb0wned
i wouldnt have dared done that
rico05
Geez, I cranked it. No damage was done, nothing bad happened. I did it for NO more than 15 seconds TOTAL. Approx. 3 times @ 5 seconds each. I really don't care about this engine. I am buying a complete CA setup next week-ish, and having it installed before the end of May, so no biggie...
spec-u-later
Car: Yaris...FML
I'm gonna take a stab at this and say rico05 is being sarcastic again. At least I hope.
Touchdown038
Car: Computers, cars, sports
Goodness, what a pointless thread this turned into.
There is no harm with just cranking the engine without the valve cover, minus oil getting in bystanders' eyes. If you run it without it for too long, well, no oil pressure + running engine = engine death.
And cranking without spark plugs won't hurt an engine.
alex7542
thank you touchdown u set everything straight. runnign a car with no spark is just like if ur distributor went bad or coil wnet bad or wut so ever the car wont turn on. and if the sparkplugs are removed while u crank it ur going to just have a lil gas spray out the hole with compression. thats it. there is no harm at all done to it.
how do u do a compression test u take the spark plug out and install the gauge. thats it theres nut bad with it.
Thecollector
Car: Computers, cars, midevil items
OMG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
i have done this also when i was trying to find out wth i broke in my engine, thought maybe it was some kind of valve problem so i asked someone to turn in while i check and make sure they were all initiating right, turned out to be a rod knock :(
