Can I throw an OBD2 KA24DE into OBD1 Chassi
max240sx
Car: 99 EK Hatch LS/V-T, 93 240sx Coupe On it's way to BOOST........
My guess is since they use the same engine code, the mount and everything else should be the same. The big concern I have is wiring issue. Will it be a problem?
Thanks in advance.
max
onosqv
Car: '92 240sx Vert
I believe you will need the entire harness/ecu/sensor/etc from the obd2 car. There's a write-up somewhere on this forum if you search or check the articles section.
