Can i tap the oil pan here? Please help
S13xCrazy
Car: 1993 240sx Vert, 1993 BMW 325i, 1993 Honda CBR F2, 1998 Infiniti Q45,
Can i tap the oil pan where I have the red mark?If not where can I tape for a bottom mount t28 turbo?
I did search, however the other ones i found are for T3 or have cheaper line. I am using braided line so I want a straight shot.
In the other spots i need a weird bend and such, this would be a straight shot.however, does the depth of the plan play a bad role in drain?
Thanks,Tony
eazye2000
Car: S13 KA-DET
that spot will be ok. No problems at all.
Although some people are hell bent on telling you that the oil line has to be perfect, and yadda yadda.
480sx
Car: 1996 Pearl White 240sx
As long as its as close to the top of the pan as possible you will be ok.
kouki_hmongster
Car: Want 97 kouki
As long as it is higher than the oil level then you should be fine. you can test by filling it up w/ like 4 qrt of oil to see where the level would be and just make sure to do it above oil level. make sure if you are making your own oil lines that the return line is bigger than your feed line.
