Can i ?!?!?!
240sxcl50
Car: 95 s14
My car is a 96 with a kouki swap i was curious if i had to buy a 97 or 98 front bumper and 96 every thing else?
biggie
Probably depends on how the swap was done.
A normal swap would have done everything (bumper, bumper support, hood, fenders, headlights, headlight brackets, corners). Those are all different from 95/96 to 97/98.
240sxcl50
Car: 95 s14
Poop i have no idea it was done when i got it.
ZombieWolf
Car: 1992 240sx
All that should be different is the front bumper, headlights, fenders, and hood. So buy 97/98 if you need that stuff or tail lights, everything else is the same between 95-98. I think thats what youre asking, does that answer your question?
biggie
Taillights are interchangable, but are different styles between zenki and kouki.
Forgot to mention grille being different between the 2.
I'd find a local person with a real kouki and compare to see what on yours is different. As I said I believe kouki bumper support and light brackets are different, but its probably possible that someone could have modified them to work.
Also to be sure. You do have a 1996 model right? And someone said they swaped the kouki front end? Just making sure you don't actually have a '97 model with a '96 manufactured date.
ZombieWolf
Car: 1992 240sx
Bumper supports and headlight brackets are different im pretty sure, i havent really seen anyone even use the bumper support when theyve done the swap
240sxcl50
Car: 95 s14
ZombieWolf wrote:I think thats what youre asking, does that answer your question?
correct also the kid who had it before me did the swap. Everything is good i dunno about the bumper support though :frown: . i need to get the whole car painted cause the front doesnt match the back its like 1 shade off but im realy anal about these things ill look at it even though i have no idea what im actualy looking for lol.
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
I still have no idea what you're asking? Are you replacing parts because they're damaged? Or just getting it repainted? Having the different front end is not that big a deal, it doesn't affect anything mechanical. If its a kouki, and you need to replace some front body part, just get the part from a 97-98. Simple enough.
240sxcl50
Car: 95 s14
SX APPEAL wrote:I still have no idea what you're asking? Are you replacing parts because they're damaged? Or just getting it repainted? Having the different front end is not that big a deal, it doesn't affect anything mechanical. If its a kouki, and you need to replace some front body part, just get the part from a 97-98. Simple enough.
i have a 96 it was zenki now kouki swaped i was courious if i wanted a body kit if i would just get a 97 front and 96 rest of the way around or if i could do 97 all the way around cause they dont look like they changed to me.
fame_s13
Car: 1997 S14 KOUKI
2008 SCION tC
if u want to put body kit on already converted kouki..just get a kit for 97-98 yr..but it should be really same for 96-98...but everything fits!
240sxcl50
Car: 95 s14
cool cool i just needed to know what the situation was i know somme about 240s but thats like next to nothing still.
SX APPEAL
95 Maxima SE 5MT
Oh OK... you didn't mention body kit in your first post. If thats the case then yeah just get a kit for a 97-98, cause the front end is the only thing thats different, lots of people run kouki side skirts and such on their zenkis, it all bolts up.
240sxcl50
Car: 95 s14
Ok thats good information to know thanks everyone.
driftneil
Car: A pile of cars.
Every part from the 95-98 are interchangable, just depends which front you want on.
Where are you at in PA bro? I have a kouki bumper, fenders, and hood, all aftermarket. and I also have everthing for a zenki too. Hit me up, maybe we can strike a deal.
[email protected]
240sxcl50
Car: 95 s14
Im in duncansville near altoona but im just askin for now cause money is a little short i still need to find a place to store it it just started snowing and im getting a motor swap first the motor in mine is gona go soon and i figure when that happens ill get the swap done.btw know any shops that do swaps good i dont have the tools or knowledge of turbos for something like that.
driftneil
240sxcl50 wrote:Im in duncansville near altoona but im just askin for now cause money is a little short i still need to find a place to store it it just started snowing and im getting a motor swap first the motor in mine is gona go soon and i figure when that happens ill get the swap done.btw know any shops that do swaps good i dont have the tools or knowledge of turbos for something like that.
If you dont have the money....WHy are you even thinking about a front end swap? Get the car running first........
240sxcl50
Car: 95 s14
The front end is swapped but some guy said if i took off the kouki bumper that the aftermarket kouki one wouldent fit i would have to get a zenki bumper? i was jw i definantly want the car to run good before any visual stuff.
driftneil
Ah I see....Well I have a aftermarket kouki bumper and fenders....I would trade if you want
240sxcl50
Car: 95 s14
Thanks but its gona stay as is for a wile i just put it away for the winter.
SX APPEAL
95 Maxima SE 5MT
240sxcl50 wrote:The front end is swapped but some guy said if i took off the kouki bumper that the aftermarket kouki one wouldent fit i would have to get a zenki bumper? i was jw i definantly want the car to run good before any visual stuff.
If the stock kouki bumper is hanging on there just fine, any aftermarket one will too
