matt123https://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113can i swap the head of a dohc ka24 onto an 89 block??? NEED HELPMon Mar 16, 2009 4:04 pm
Postby
matt123 »
https://forums.nicoclub.com/matt123-u129230.htmlMon Mar 16, 2009 4:04 pm
i just bought an 89 240 i have the motor for it i was just wondering i could buy a dohc head and swap it onto my block replacing the sohc head? I also bought a 92 240 which came with the ecu for a dohc engine which i know i will need but i also have the wiring harness and i am not sure if i will have to swap that aswell ! Are the harnesses the same from the 89 240s and the 92's??? oh and by the way the 92 240 was motorless only the trans was there.
Postby
LingeringSuicide »
https://forums.nicoclub.com/lingeringsuicide-u38046.htmlTue Mar 17, 2009 5:19 am
No... DOHC will not bolt up to a SOHC. different block all together. DOHC head has a hemispherical spark plugs vs. the side mount of the SOHC. Intake is completely different on the DOHC. This piston configuration is different as well.
You either need to find a SOHC head or do an engine swap. Either way there are lots of write ups covering this subject. the search option in the upper right corner of the site is a great place to start your research.
Postby
matt123 »
https://forums.nicoclub.com/matt123-u129230.htmlWed Mar 18, 2009 1:41 pm
well that is good to know i guess i am engine shopping lol i have one more questions are the injectors in the dohc high or low impedence injectors if you dont know do you know the resistance that runs through them?
Postby
matt123 »
https://forums.nicoclub.com/matt123-u129230.htmlThu Mar 19, 2009 5:22 am
