Can I swap My digital speedo for a non?
pizza914
Car: golf & cars
Just currious if I can take the gage cluster out of my 94' vert & then swap it for the digital one from my 91' coupe? Are the plugs all the same? If I had to change any wiring I doubt I would bother. If it just an unplug & plug the other in. I'll do it tommorow night- Thanks
No.
The digi cluster (HUD) uses a different harness.
I have contemplated obtaining a digi cluster, HUD unit and harness and retrofitting it into my 'vert.
Scary to consider cutting a hole in a pristine dash though!
pizza914
Car: golf & cars
I have everything in my coupe! I could just swap it all. I didn't really want to do a major overhaul to do it though Maybe it's just one of those grreat projects that are never going to happen
Not a bad project then - just swap the dash and all straight across.
top_secret
actually all you need is the cluster subharness, it plugs into the dash harness back behind the cluster. You can unplug it without pulling the dash! and you don't need to install the HUD, you can swap the digital cluster over without plugging the hud in and the digital speedo should work.I have HUD in my vert but I swapped the whole dash over from my coupe.:-)
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
It's plug and play... you just need to unhook the subharness.. (about a foot long)
jamesblonde82
Car: 1992 Nissan 240SX convertible RIP 5/10/07
1993 Nissan 240SX convertible
so if i found a junkyard coupe with the digital with HUD, i can take the dash (which i need to replace anyway cuz mine is cracked) and the cluster and the harnesses should all plug up?
top_secret
yes. what year is it? dohc cars need tachs from dohc cars if you want the tach to work right, and you should know that the analog tach is a different size than the HUD tach so it may be difficult (or at least look odd) if you swap your analog tach into the HUD cluster. ideally you need a HUD off a dohc car, which is pretty rare, so you won't have to swap anything. You can make a dohc analog tach fit the sohc HUD cluster its just a bit of work and depending on how you do it it may look odd. I swapped needles on mine but the tach never worked quite right after (its like "slow") but I didn't care since I have an aftermarket tach anyway.
Swedish Mike
Car: Golf TDI, Volvo 850T5 and 200sx S13 Hatch
Do you guys have a picture of the digital? We never got them here...
/Mike
jamesblonde82
it's a 92'..... i'm going to start looking for a dohc hud to switch over to. anyone know where i can get one?
top_secret
forums or junkyard.
joes217
Car: 89 240sx
do a search about all the digital speedo/hud problems.. mine is shot out and awaiting repair. just a heads up
Malac0da13
Car: 1992 Nissan 240SX Convertible
i see em on ebay once in a while a whole "kit" (cluster and harness)
