Chezedik »
https://forums.nicoclub.com/chezedik-u3691.html
Tue Feb 22, 2005 7:19 pm
Well, my idea for intercooling was essentially on the custom manifold, with rifled runners that we intend on producing, I have decided to incorporate an internal exchanger to water, where the hosing will be ran to the front of the vehicle and exchanged to air. My intent is to do everything I can think of to lower the chance of detonation, so that higher levels of boost can be run on a stock engine. I also have a friend producing the head gasket to drop compression to the 9.0 to high 8's range. I will need to look into what similar turbo setups and supercharged setups have done, and make some decisions. Anybody with any ideas that could help, I would appreciate. Yes, I fiddled with the idea of the shaft and turning the blower around, and by doing that using only an adaptor plate to the manifold, but we came to the conclusion, that the shaft would be best supported with two carrier bearings, which would be nearly impossible to perfectly align, not to mention the possibility of running bolts into coolant passages, or warping the deck by welding them on (NO LONGER SERVICEABLE). And even with a single carrier on a screw tensioner, you would have awful balance issues on the shaft resulting in damage to the charger or the engine. The more carriers you add the more you aggrevate the situation. Long story short, it is not at all feasible to do it that way. I have also given some thought to UBERs idea, but I just can't get my thoughts past the tremendous amount of heat that the charger must absorb, being so close to the header. So, I still think the custom manifold will be the best plan of action, and require the least piping. I was thinking of a few supports for the charger in order to keep weight from stretching studs and damaging intake gaskets (which will already be stressed if it works). But since this is my post, I feel entitled to my two cents. But anything anyone can help me with would be appreciated. I must say a few of the posts have been 'food for thought'.
