AZhitman wrote:Turning the car off means no P/S and no ATF circulation. It also won't start without actuating the brake.
msvara is right - Unless you want to be a colossal hazard to the rest of the people on the road, fix your hack.
While you do lose P/S, that probably isn't a big deal for a guy like Antz, who remembers when nobody needed it (kinda like electric starters on motorcycles). Regarding losing ATF circulation, I can't imagine that this matters for the few seconds the engine is off (it'd be no different than if the engine stalled even if you had to stop afterwards). Those comments having been made, it WILL start without the brake when you are rolling in neutral (IIRC, it doesn't even have to be at a very high speed). My 2006 M45 will, anyway. Moreover, I'd say someone with plenty of experience doing something like this is far less dangerous than a lot of people on the road every day (because it's far too easy to get a license and beyond that, far too many people are talking/texting on their cell phones or otherwise distracted). I have done this a number of times (throw the car in neutral press the button 3 times fast or hold it for a few seconds) when the ICC has messed up (specifically, because once it says dirty sensor, you can't use standard cruise without turning the car off and back on, and that is an Infiniti problem I can't fix). This does reboot the ICC, and I think it might actually reboot the Nav/Radio, too, because even though the radio keeps power in ACC, I'm pretty sure they reset when the starter runs in this case. That is to say, IIRC, the starter draws enough juice to cut accessory power in this scenario. Sometimes it works great, other times I have still to pull over and stop and restart the car because it does something else that irritates me afterwards (I don't remember what, maybe it stops using the torque converter or runs in a lower gear, it's something strange, but not too alarming). On that note, personally, I'd say it's worth a shot. One word of warning, though, it won't start immediately after it shuts off; you have to coast for a few seconds (maybe 3-5, but maybe not quite that much, again, I don't remember, but if you hit the start button and nothing happens, don't panic or get goofy, just wait a few seconds and hit it again. Finally, while I think Antz is well aware of this, I'm going to say it for the benefit of the random lurker: Obviously, it's important to remember that you're liable for your own actions, and this could potentially be dangerous, so be cool-headed and prepared (to turn on hazards and stop with no power steering [and possibly no power brakes]) if you're going to try it. Also, it would probably be best to try it once where there isn't other traffic before doing it to fix an issue in other traffic, and highly recommend waiting until you're in a position to pull over if necessary before trying it every time.
Regarding diagnostic mode, that might be a better idea for this particular scenario (just wanting to reset nav/radio), although it technically requires more distraction, so ymmv.
