Hey guys, I found this:
zer...wpics
and was wondering if the TORQUE specs for the bolts were the same on my RB25? (Poster is using an RB20)
"Install water pump and torque 10mm bolts to 35ft lbs, 8mm bolts to 15 ft lbs, and the 6mm bolt to 11 ft lbs per FSM. In the FSM it is in Kilogram Meter, but that is the standard equivalent. Torque pattern is clockwise starting with the 6mm bolt."
and
"Install idler pulley and torque to 40 ft lbs. Install tensioner pulley with spring on the right side of the lower stud. Be sure that the convex thin washer is facing outward on the pulley itself, then the flat washer, then the nut. Rotate pulley with 5mm hex/allen clockwise and lightly tighten" 14mm nut.
Modified by johnny butt at 6:28 AM 10/8/2009
