Can I run a FMU with 370 injectors?
240ingthe240er
Car: Coupe
Setup is:
t3/t4 50trim .63arz32 maf370 injectors255 walbro8-9 psi
What kind of ratio should I run?
WDRacing
You can only use the FMU with factory injectors. The FMU increases fuel pressure as boost increases. It's function is to prevent the need to replace the factory injectors with larger ones.
You can't use larger injectors without some means of tuning for them. Such as the SAFC or a ROM tune from JWT or EFI Specialists.
You can't just install 370cc injectors without a tune or you'll ruin your motor, if it runs at all.
WD
240ingthe240er
Car: Coupe
Thanks, WD
tom550
Car: 240sx 1990
can i run injectors under fuel pressure?
seriously of course you can. you just need it tuned for that pressure.just get rid of those 370's and get some injectors thats good and can handle your set up. go grab some bigger injectors and do it right.
wow my first post and i had to see this.
WDRacing
240ingthe240er wrote:Thanks, WD
