can I replace just the clutch?
JdrifterCA
Car: 1992 240sx LE
Hi, i droped my transmission because it had a throw-out bearing problem. IT was fking hard to get it down, while at it, i mind as well as replace the clutch plate also. I have a maxiuma clutch kit on right now. Would it be ok if i dont replace the pressure plate, but just the clutch? The highest hp my car will go is about 300. right now dynoed 200lbs at the wheel.
ZOMG.SR20
Car: 1990 s13
umm why not replace the whole thing while its out... but yes you can do just the clutch but you need to resurface the flywheel too
