Can I remove my oil pan w/out pulling the engine
Gmans13
My ka24de has a severe knock after running 2 quarts short for i don't know how long. I am trying to remove the oil pan to see if I can just replace the bottom end berrings. I got all the bolts for the pan off and I got the pan loose but I can't get it away from the car. Some one tell me if there is even a chance for me to get buy with just replacing the berrings and if any one knows a good short cut on removing the oil pan please let me know. My Ka has about 91K miles on it.
Cold_Zero
Car: 2003 Nissan Altima SE 3.5
2005 Nissan Pathfinder
Gman,Repoman's brother had oil leakage problems in his KA Altima. If I remember correctly you do have to loosen the engine of the mounts to get at that part of the engine.Good luck
nlzmo400r
Car: '02 Nissan Altima QR25DE
'93 Nissan 240SX hatch KA24DE
i think cold-zero is right, my friend has a KA 240, and he had to go through the same loosning of all engine mounts, but it really wasnt that bad, jus make sure u have a friend to help and keep company
Gmans13
thx
nlzmo400r
anytime, glad we could help
Simmsled
Car: TSI GTI - E46 325i
i hate gaskets, with exception to the head gasket (knock on wood) i have replaced all of the gaskets that could possibly leak oil (with exception to the timing chain cover gasket (a pain in the *** and still leaking oil which will be fixed as soon as I get out of college mode and back into making money over the summer mode). My KA was/is a leaky b i t c h
nlzmo400r
yea its just one of those pain in the *** type things taht you have to do, but you feel more confident after you're done, knowing thats ONE less thing that can screw up in the near future on your car
EZcheese15
Car: 2012 Juke SV
2011 Titan Pro-4X
2007 BMW 328i
nlzmo400r wrote:i think cold-zero is right, my friend has a KA 240, and he had to go through the same loosning of all engine mounts, but it really wasnt that bad, jus make sure u have a friend to help and keep company
The 240 is going to be a ton different. Not even remotely the same (FWD vs. RWD makes a big difference in positioning of the oil pan).
I don't know if you have to lift the motor on the Altima or not, so I can't comment. Just wanted to get the point accross that the 240 and Altima are different.
nlzmo400r
o yea, i didnt think about that, thanks Torry
