struckinc »
https://forums.nicoclub.com/struckinc-u34763.html
Wed Mar 08, 2006 1:09 pm
all j30 and 300zx came with lsd...the cover you have to swap is yours off of your non lsd onto the lsd rear end do it can bolt up...the z32 and j30 and s14 have 2 bolts on the rear cover that bolt up to the rear crossmember..the s13 has 4..just take your rear end out...change fluid unbolt yours and bolt onto the lsd rear end...same size and bolt pattern just different internals..if you go with the 95-96 rear end you dont have to change the axles
