Lobo240sx »
https://forums.nicoclub.com/lobo240sx-u173545.html
Mon Sep 10, 2012 8:30 am
No. They are worn and stretched. If you put them back on, you could break the stud into the head/block causing all sorts of nightmares. Stock studs are cheap. Make sure you get the assembly lube with them if required. I don't remember if you install them wet or dry for stock studs. Refer to manual.
