can i put a sr20de in my 89 240 sx body
pete7452
Car: 89 240 sx ka24e
same questin
Sileighty_85
Car: 1991 180SX
Yes
Same swap as a n SR20DET with less work.Engine harness need to be rewired and Tach swapped for a DOHC TACH
s13mike91
Car: 91 240sx hatch
good luck with mounting a n/a front wheel drive sr in a rear wheel drive car. bell housing is different.
pete7452
thankyou mike for the help
Sileighty_85
Car: 1991 180SX
s13mike91 wrote:good luck with mounting a n/a front wheel drive sr in a rear wheel drive car. bell housing is different.
are you serious?
180SX's and Silvia's also came with SR20DE's they drop right in.
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
Yeah, but we don't waste our time importing them. The fwd ones are different in head design, mount locations, and bell housing among other things.
zachattack_5491
Car: Pignose S13 Redtop SR
Sileighty_85 wrote:
are you serious?
Sileighty is right. My friend has the DE in his 95.
the converted
Car: '99 BMW M3 6.0
'20 Toyota Tacoma
But why would you want to? It is hard to find a rwd one and they make less power than a ka that you can get anywhere for dirt cheap. If your planing on building an na screamer that is different, but I doubt that someone who is asking if it would fit would be doing that.
s13mike91
Car: 91 240sx hatch
who would you want to put an na sr in a 240 when the ka has more power. the money that you put into getting a rear wheel drive sr (if you can find one and not out of a sentre) you can put toward a ka and have even more power.
