:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Wed Apr 13, 2005 5:16 am
YES, it will bolt up just fine.
It's a direct swap...head mounting flange is the same, length is the same, flange at the cat is the same, O2 sensor threads are the same, etc...
EGR mounting is different IIRC, but that's a quick fix (or is easily removed).
And the S14 header will have a second O2 bung by the cat...so you'll need a plug for that...certain Honda oil drain plugs will work, IIRC it's a 18X1.5 thread plug that you need.
- Brian
