CAN I PUT A 95 ENGINE/transmission IN MY 93 J?
eergsxr
I CAME ACROSS THIS KILLER DEAL FOR THIS ENGINE/transmission SO I WILL LIKE TO PUT IT IN MY CAR, CAN I USE THE 95 transmission ON MY 93 BLOCK?
THANX
ANY INFO IS GREATLY APPRECIATED
Defiant
Car: 1997 J30
Yup. I don't know if there may be wiring fiddling involved, but the hardware should be same-same.
eergsxr
i already noticed the wiring a little diffrent, has anybody ever done this?
95-J30tt
Car: 95 Infiniti J30tt (Twin Turbo)
the transmission should fit, and wiring shouldnt be a problem, but i think that in the 1993, there was no output shaft rev sensor, but it is there in the 1995, so i think that you will have one less wire to connect, it will not interfere with the functionality though
the engine is a little different when it comes to wiring, the injectors of the 1995 are the newer ones (that is the case with the 300zx, so i'm not sure if the 1993 J has the newer or the older injectors), if the injector plugs dont fit, just splice them in, and again, it wouldnt effect functionality
