can I put 215/45/17 on the B16??
hangout
Car: 2007 FX35,, 2016 Q70L
I have the 2007 sentra 2.0
my friend selling me a set rims with 215/45/17 tires.can I put these tires up on my sentra without touching the suspension system but still drive good? anyone did this before, I need the answer quick.. PLEASE..
Thanks
Faja
Car: 2009 Nissan Sentra
Those should fit fine.
cycspec-v
Car: 2007 Spec-v
stock on the spec-v is 225/45/17 so you should be ok..
nametakennow
Car: '06 MINI Cooper S
Not sure what your stock tire size is, but to keep your speedo and odo accurate make sure the diameters match. I'm almost certain that 215/45/17 is pretty close.
http://www.miata.net/garage/tirecalc.html
Definitely won't rub, though.
hangout
cycspec-v wrote:stock on the spec-v is 225/45/17 so you should be ok..
the sentra I have is not the spec V.. it's 2.0 CVT 4x114current has 205/60/15 on it..
should I go get the 3mm spacer for it as well?
Thanks
Modified by hangout at 10:39 AM 10/13/2009
hangout
nametakennow wrote:Not sure what your stock tire size is, but to keep your speedo and odo accurate make sure the diameters match. I'm almost certain that 215/45/17 is pretty close.
I did try that site,, it really works good. Thank you very much..
nametakennow
Depends on the offset. If it's very high (mid to upper 40's), then a spacer would be a good idea. Otherwise there's no need.
