can i make 10sec with a ka24det
achillies0701
Car: nissan 240sx (s13)
will i be able to make 10sec with a ka24det without spend as much as i would to put a rb26 swap in my car, and if i can will it last as long as a 10sec rb26 swap
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
OF course you can make a 10 sec daily beater(reliable) with ka24de-T,
use the power of SEARCH.......
nelson8708
Car: 1989 Nissan 240sx Fastback
1994 Acura Integra LS
Add another milla second to the injector pulse width, tune the timer and you'll run 9's
I'm not one to flame but, you had it coming asking a question like that.
achillies0701
thank you for giving me hope, i know that an rb26 would be sick in my car but, if i could build a KA motor without wasting my time and money on trying to to hit 10 and have it still reliable then i will jus do that but i just dont know were to start, all my friends they have hondas and they wont help me cause my car smoke them already
240sxvaj
achillies0701 wrote:thank you for giving me hope, i know that an rb26 would be sick in my car but, if i could build a KA motor without wasting my time and money on trying to to hit 10 and have it still reliable then i will jus do that but i just dont know were to start, all my friends they have hondas and they wont help me cause my car smoke them already
now its time for you to talk smack to your friends and make em sell their honda to get a nissan lol!
hondas are weak without V-takkkkkk!
SX APPEAL
Car: 06 G35 Coupe 6MT
95 Maxima SE 5MT
nelson8708 wrote:Add another milla second to the injector pulse width, tune the timer and you'll run 9's
Excellent...
The 240sx isn't the best platform for drag racing in my opinion though, wanna go fast in a straight line, get a small block chevy, a glide' n a brake'
480sx
Car: 1996 Pearl White 240sx
s13 is a great platform to drag with. You can strip the car down to be pretty damn lightweight, its RWD, solid axles and rear dif. The list goes on.
The KA24DE-T is in the 7 sec quarter mile range now. Filled block, drag only o/c.
motoman399
Car: 98' wrecked (RHD coming soon) 240
REALLY.... thats awesome. what is filling the block?
spank044
Car: 1992 240sx with a Supercharged 350Z VQ for a HEART!
block filler is used to support and strengthen the bottom end by filling the water jackets with a cement like substance like hard blok.HARD BLOK WATER JACKET FILLER is a specially formulated, cement-based product with refined, size-graded iron particles combined at an optimum ratio to provide maximum strength, vibration dampening, and heat dissipation required in high performance race engines. Its coefficient of thermal expansion is identical to cast iron engine blocks. Product has been tested and proven effective in aluminum blocks.
* Remains stable at all operating temperatures. Does not soften when exposed to high heat, nor erode under water. * Fills the smallest spaces in the water jacket. Does not shrink or pull away from the cylinder walls. Does not expand. * Extends cylinder wall life both by preventing cracked walls and by causing the walls to wear truer. Honing is minimized during rebuilds. * A race-proven advantage used by winners in all types of racing since 1986. * Non-hazardous and non-corrosive. Contains no toxic material. Once hard, it cannot be removed from the block.
