Mark.Mann wrote:i am installing a homelink/autodim/compass interior mirror in my 2013 altima coupe. i want to say thanks for the wiring diagrams. one question, after looking at the mirror install i am still a little confused as to what wires i tap for 12V constant 12 acc thanks mark
If you have model number for your mirror than you could get a better instructions for it. These instructions I found off 2015 Murano mirror manual. Not sure if color coded wires are the same:
22)Using a posi-tap, connect the BLACK WIRE W/ SILVER CONDUCTOR from the mirror harness to the BLACK
wire on the accessory connector harness. Using a posi-tap, connect the BLACK WIRE W/WHITE TRACE &
COPPER CONDUCTOR from the mirror harness to the WHITE wire on the accessory connector harness. Using
a posi-tap, connect the BLACK WIRE WITH THE BLUE DOT & COPPER CONDUCTOR from the mirror harness
to the RED wire on the accessory connector harness. (Fig. 17)
