Can I have some bass with that Z ?
Z-bass
Car: 1993 Z32 N/A 2+2 AT
1994 Z32 N/A 2+2 AT
2005 Pathfinder
You certainly can ! And here it is :
And where did I hide the power amp ? Right here :
everpresentnoob
Car: 1990 300zx Base. Manual and abused by previous owner....
Um, ok. any details as to what it is? Because looking at the pic it seems you just put maybe a 6 inch driver in the back of your seat and have a small amp hooked to it.
Im assuming you built a box inside the seat cushion.
not tryin to knock you, just want details man! :)
Z-bass
1994 Z32 N/A 2+2 AT
2005 Pathfinder
Close on the size - its actually a 5 x 7. That's the max you can mount there (with a very narrow bezel !), and retain the functionality of the back seat (being able to fold it back (a design challenge !))
The speaker is mounted to the metal backing structure (cut out to match the speaker dimensions) with the speaker pressing against the seat cushion (the cushion is molded directly to the backing structure). I ported the bezel (2 holes on each side of the bezel) to gain some bass response in lieu of building a box, as there was definitely no room, and foam kills bass response. With the seat up, you would not know the speaker was there.
Yes, the amp is small, but you don't need a lot for that speaker size, and it had to fit in a small area. Considering all of the gear is out of the way (more of a "stock" look that I was going for), it adds much needed bass to my overall post-Bose audio system (5x7 tri-axials all around w/ aftermarket head).
centralcoaster33
Car: 1997 Nissan 240SX #5
Nice stash, and the driver faces forward. How's it sound?!
Z-bass
1994 Z32 N/A 2+2 AT
2005 Pathfinder
As I said to EPN, its an improvement.
Will it go up against 10"s-in-a-box ? No.
Then again, you won't have any storage space if you go that route.
Depends what you're looking for...........
Z-bass
1994 Z32 N/A 2+2 AT
2005 Pathfinder
Some additional notes: This is version 3......
ShawnTexan
Car: 300ZX, Nissan Titan
nope no bass here
NolimitZ32
Where do you put the T-Tops?
Z-bass
1994 Z32 N/A 2+2 AT
2005 Pathfinder
Good question, NLZ32 !
ALSO, there's a spare tire/tools/other gear down there somewhere (that you may need sometime! - you can actually see some of it earlier in this post!)
Why I "toned" it down a little.........
ShawnTexan
Im working on a bracket to hold the T-Tops still designing it or i can leave them in garage or i can put them in back seat. Spare tire and jack is gone who needs that s*** really just tow it to get it fixed road side assistance.
