can i get some input on best boost level
f s t caz
Car: VG30ET D21 Extended Cab Pickup
finally got my CA up and running. It's basically entirely stock, minus a GTiR T28 and a cone filter. I was running ~9-10 psi for a day until i installed a different hot pipe w/ a BOV attached, and for one reason or another it lowered my boost to 6-7psi. I just searched and saw that stock boost was 7psi, and that people don't recommend pushing the stock turbo/intercooler/injectors past 10psi, while others were saying 12. Naturally, 10psi is more enticing, but if it means blowing up my motor or anything that would otherwise harm my investment, i'll hold off until i can upgrade. Thanks for the input.
Chris
Doogz
Car: '89 240sx coupe
10 psi is fine by me. That's what i ran stock. Also ,check your connections around the new hot pipe and such to make sure its all good and tight. Could be that the pressure is just leaking off somewhere.
datsunboy
Car: Datsuns
what bit is the hot-pipe?and I thought stock boost on a CA was 10psi?
Doogz
The hot and cold pipes are referring to the pipes going to the intercooler. The one from the turbo to the intercooler is the hot one and the one from the intercooler to the throttle body is the cold one.
I always thought 7psi was stock...but i dunno.
boost_boy
Stock boost is between 5-7psi! 12 psi of boost won't hurt the engine, but your fuel system is out of gas at this point. With the Gtir's T28, your car will be a bit more efficient and can run 12psi safely.
Dee
float_6969
My T2small is running at 9. I don't know why, it just does. I haven't touched it.
r34 gtr
95.5 Audi URS6 Avant 5spd
03 BMW 330i ZHP 6spd
89 Nissan 240SX base CA18DET
my ca t25 is running at dead, because i cooked it. i havnt touched it either, except for the bleeder valve and the whole....ok, i touched it.
- tim
r34 gtr
oh, and why does my turbo look different than the others ive seen? mine isnt an aiResearch-looking unit, it just says "garrett" in raised lettering like the gt28 i just bought. same .48 a/r and everything though.
- tim
boost_boy
Quote »oh, and why does my turbo look different than the others ive seen? mine isnt an aiResearch-looking unit, it just says "garrett" in raised lettering like the gt28 i just bought. same .48 a/r and everything though.[/quote] Because you're special.
Dee
