Very useful tool for comparing tire sizes (Canadian members might find it slightly less useful as it only has US 5mm sizes and not the even sizes available in Canada):
http://www.miata.net/garage/tirecalc.html
blind_snyper wrote:yes they will fit, but they are over 1 inch shorter in overall hieght and your speedo will be off by almost 5 mph.personally i wouldnt do it
Keep in mind that speedo inaccuracy is not linear. It's a percentage. The discrepancy increases as speed increases. A 3.5% difference is under 1mph off at 25mph, and 2.5 mph off at 70mph.With my short-geared rear end, I have a discrepancy of about 4mph at 25mph, but at 70 it shoots up to 10!
LaKate wrote:I can have a deal on almost new winter tire. The size is 205/50R15. Is it going to fit on my Versa ? I think my speedo is going to be off a bit and that is no problem for me but beside that is there any other reason I shouldn't take them ?
205-60-15 would be a better choice as they are very very close to the stock 185-65's rolling diameter.
superskunk wrote:there are speed sensors...
Yes. And those speed sensors (actually, it's singular sensor) use rotational speed from the transmission output shaft to determine speed. So if you have tires with smaller-than-stock rolling diameter, the speedo will read high. Taller tires will read low.
superskunk wrote:when i had my 20's on the speedo was correct...
On the Versa? Doubtful. How do you know?
