Can I fit 18x9.5 and 18x10.5 on S14 w/o fender work?
SoCalSilvia
Car: S14- 1995 240sx
Just like the title says. I've got a 95 240SX and I wanted to know if I can fit 18x9.5 in the front and 18x10.5 in the rear? Tire sizes are 235/35/18 in the front and 255/35/18 in the rear. Offset is in the low 30's.
Also, can I fit 235/55/17 tires on 17x7.5 and 17x8 rims?
Thanks for your help guys.
aither
Car: Rock Climbing
you may need 10 or 20mm spacers up front just to clear coilovers or to prevent rubbing the frame rails. At least, the rear will need some pulling. You might get away with a lower offset up front if you have enough negative camber.
SoCalSilvia
thanks for the reply aither. I don't have coilovers, I have Tein S-Tech's with KYB GR-2's. So I will definitly need fender pulling in the rear?
Oh and my other question, I've got 17x7.5 and 17x8 rims currently and I wanted to know if can I fit 235/55/17 tires on them. Thanks for the help.
