Can I find the turbo hardline banjo crush washers/slipon washer from the dealer?
Deadrodent
Car: 1992 240sx hatchback
I have a quick question...I'm missing the slip on washer thing that slips over the hardline (like 2 washers with a metal piece that connects them together) Could I find this at the dealership/local parts store? If I can do you guys know the right name/sizing for our application? I have the bolts but no slip on washer thingie...and i heard you need crush washers too?? It's setting me back a lot!
Hijacker
Car: '92 240sx Convertible
'94 F-150
You can just go to Lowe's or Home Depot and pick up two copper washers for like .50 You won't have the nifty metal connecter, but that's a luxury IMO
If you don't have copper washers on there, you will leak coolant and oil at those bolts.
Deadrodent
is there an actual reason for the little metal connection between the two washers?
James@CI
Car: 89 Nissan 240sx with SR20DET
Well yea the banjo bolt is drilled out and feed trough the side and into the line through the fiting.
James@CI
Contact me at AIM sr20detswaps I can get you everything you need.
Hijacker
'94 F-150
Deadrodent wrote:is there an actual reason for the little metal connection between the two washers?
It's there to make it a little easier to install the washers. It's only job is to keep the one on the block side of the fitting from falling off and frustrating you. Other than that it has no purpose. Nissan didn't use the bracketed copper washers on my motor.
CMG
Car: 1989 240sx Hatch w/ Redtop
I wish I knew about those bracketed washers before I pulled my manifold a few times. Would have saved me a couple hours of reaching under the manifold and trying to put the banjo bolt and washers on with one hand.
